Hy gentlemen.
I continue to restore my 1978 fleetwood brougham d'elegance, and I need again your help or you ideas to solve a little problem.
This time, I try to fix a problem with the A/C system. The blower is operating only in defrost.
When actionning the control panel from Off to economy, nothing happens
From economy to Low: I can hear the compressor relay operating.
From economy to auto: nothing happens
From auto to high: nothing.
From High to bi-level : nothing
form bi-level to defrost: I can hear the vacuum operating, A relay operates, and the blower instantanly runs in High speed.
I've check the blower fuse on the fuse panel. It is OK.
I've checked the blower wiring form the central plug uder the hood to the blower motor. It is OK
I've found a blower relay, not so far from the fuse panel in the passenger cabin (the one that operate). it is a 5 pins bosch number 25525638.
I've visualy check the termistor near the blower under the hood; It seems to be OK
In the shop manual, This problem is identified as an electrical problem... without any other comment.
Up to you what control should I do to fix it ?
thanks for your help.
See you guys.
See you guys.
