1 - 11 of 11 Posts
1995 SEDAN DEVILLE-4.9 & 1978 SEDAN DEVILLE-425
Seems to be a slow leak in my `78 Deville brake master cylinder.
Look to be the original one.
Had brakes checked--no leaks. No brake light warnings yet.
In the master cylinder there are 2 separate bays that hold the brake fluid--the rear bay nearest
the firewall is the one leaking---have to add brake fluid to it every month or so.
I`ve been looking at this close for 3 weeks--sprayed down the area clean with cleaner
and it seems to be leaking from the rear of the cylinder--right where the clip that holds
the cover on inserts into rear cylinder body.
Put in new cover gasket and still leaks--but "not" from gasket area.
Do these brake master cylinders have any internal seals that could leak?
Thanks for any info.
84 Coupe w/500
If it's leaking from the hold down pivet, I'd think the metal is corroding. Don't think there is a gasket there.
Probably metal corroding,as you say.
Looks to be leaking from hold down rear "pivot".
If it`s original, and it looks to be, probably time for a new one. Held up for 37 years apparently.
The nuts that attach the master cylinder to the big round vacuum booster look to be almost fused to it.
I don`t have knowledge of replacing brake master cylinder, so I`ll have to take it to my mechanic.
Brakes are important and I don`t have a clue on how to bleed them right myself.
1979 Coupe deVille, 1995 Sedan DeVille (sold)
Yes, they do have internal seals that can fail and leak. However, if it was internal, you would not lose fluid - you would lose brake pressure.
Discussion Starter · #6 ·
I had a brand new one installed today.
Looks nice and shiny under the hood.
Got some peace of mind--for now anyway.
1990 Brougham, 1990 Brougham d'elgance 1979 Coupe
I took a can of cast Iron engine spray paint and sprayed it into the paint can cap and took a 1" foam brush and painted my master cylinder, looks real nice.
Hope the booster is still in good cosmetic shape.
The booster looks it`s age of 37 years. Still works great though!
If its gold anadoized theres not many easy options, eastwood has a spray kit, but I doubt its all that great from what ive read.
If your not worried about it, your stopping now. Black spray paint hides a lot.
Ill bet your car is pretty awesome NOW!
Discussion Starter · #10 · (Edited)
Pretty awesome!
My bank account is feeling the "big pinch" though with all the work done on both my Deville`s lately.
I set aside the cash for the recent complete repainting/bodywork on my `78 Deville and new tires on my`95---both look so great
and well worth it---but was`nt planning on new radiator and idler pulley & belt tensioner for my `95. New alternator,belt,replacing cruise and wiper switches/blades,
brake master cylinder on my `78---all in a short period of time.
On the positive side of it all---just glad I was able to find all the parts necessary to keep both running---and I was
able to do some of the work myself.
1 - 11 of 11 Posts
