1976 Cadillac Brougham D'elegance
My oem sunroof has a minor leak on one of the corners, i coudnt tell what the problem is exactly
Any common problems?
Maybe weatherstrip?
I've never had such experience, so I would assume the drain hole is by the sunroof rails?
77 CDV, 06 DTS III, 69 FWB
Yes, usually at the rear. They drain out into the rear wheelwells. Unplug them with a long flexible wire.
Should be 4. One at each corner. Open the roof and trickle water into each corner. Should drain behind the front and rear wheels.
