Hi everyone,
The smog pump on my 76 500 is making a ton of racket. If I can, I'd like to eliminate it.
Cadillac High Performance has the BL57 kit for my application (single drive A/C and P/S) that involves getting a harmonic balancer to replace the lower pulley/balancer setup. Unfortunately it is on back order with not ETA on being back in stock.
Do I have any other options? Mish-mash of pulleys, etc. from other years? Modified alternator mount? Different alternator mount? Just suck it up and buy a new pump?
Thank you
Brett
1976 Fleeetwood
95 FWB 81SDV 96 FWB 94 Fleetwood
If you can still find one , off a 77-79 car with a 425 motor non calif. and get the crank and water pump pulleys . they don't have the pump on those cars. With those pulleys the air pump does not drive the water pump. so all you need is those two pulleys.
I just thought of another thing. You can take the tube out that goes to each head and use dimes to plug the holes.
