I don't know exactly how they are fastened in, but usually, the hooks (or retainers) are molded into the plastic lens and when installed, they "spring in" to the housing. Take a small, thin flat blade screwdriver along the edges of the lens and gently pry the outside of the lens toward the center, releasing the "hook" from the housing, then pull the lens outward. Normally there anywhere from 2 to 4 hooks that hold the lens in. Be very careful, as old as the lenses are, they are fragile and may break.
What about looking for replacement lenses online, looking at a picture of the lens, that may give you an idea as to how exactly they are fastened in.
Hope this helps.
chris.
Hope this helps.
chris.
