1 - 20 of 25 Posts
74' Coupe de Ville
Hi!
I recently bought my first cad. 472+400 original.
Pretty ok but little fix.
Above 30mph vibrates strong but not in neutral. Universal joints? I already ordered those but shipping takes some days.
Automatic climate control leaks, whispering noise when I but it on. Blower goes high when I but defrost, all other positions it's low. Normal?
No warm coming either in cabin.
Is air cushion warning light in all models including models without bag?
Stars very good and choke works but in warm engine, vibrates in idle. Not engine mounts, something on distributor or carb? This is HEI.
77 CDV, 06 DTS III, 69 FWB
:welcome:
A constant vibration at all speeds above a certain speed certainly suggests an imbalanced driveshaft. Universal joints area good place to start. The whispering in your AC system indicated a vacuum leak, likely at the programmer based on your symptoms. All 74 Cadillacs will have a provision for the air bag light on the dash, but unless you have a four spoke steering wheel, you don't have the air bag system, which in any case is really rare. The engine vibration at idle coule be related to your vibration at speed, or a misadjusted carb. If you haven't already, purchase a factory service manual for your car. It will make diagnosis much easier. They're available all day long on ebay for not much money.
Good luck!
74' Coupe de Ville
Thanks for fast answers! This is my number 15 v8 American car, I can do all in DIY but cad is cad :) I mean 4 joint driveshaft and other cadillacs special things.
I have normal steering wheel, good to know that light thing.
There was no option packages except d'elegance? Options were mixed and free choice able?
Yep, back then most options were stand alone items so the buyer could order a car to his taste.
74' Coupe de Ville
When i drive rough spots on road (not speed bumbs) interior and windshield rattles very bad. All items are attached etc. No clonks or voices.
What it can be?
95 FWB 81SDV 96 FWB 94 Fleetwood
When changing the duel U joints, you must put them both together at the same time. If you put one in complete you can not get the second one in..
74' Coupe de Ville
Discussion Starter #8
Hood stops... I dont even thinked those, thanks! Hood is lifted up in drives side rear.
Yeah u joints were pretty job, much heat and big hammer. Driveshaft is little bit banana, someone has hitted it on rocks etc but now its way better. 60mph,and over slightly vibrating. I can fix it by two hose clamps I think.
When I press full throttle, engine almost stalls and says patatatata. Acceleration pump? In neutral it does same but not so bad and if I rise rpm slower it stands full throttle in neutral.
Carb is original quadrajet.
Front brakes stalled too,maybe bad hoses or caliper won't return :(
74' Coupe de Ville
Discussion Starter #9
Hood bushings was gone in rear. I changed front bushings there and i did rubber ones in front.
Hood is loose in rear, if I press it it clonks. Hope adjustment of pads helps.
New hardware kit on caliper, left has rusty cylinder but hope it will last couple months.
74' Coupe de Ville
Discussion Starter #10
If someone has devile too, i would be thankful for height measures of front and rear hood bushings. That what you can adjust like bolt and nut.
74' Coupe de Ville
Discussion Starter #11
Two red/blac vacuum hoses were off. Those are in one connector. I but it middle of dash blac clock. Now bi leven, vent etc positions work. That red/black vacuum hose number 2 is automatic brake release, where it comes? Hose is pretty short so it can be anywhere.
Also black/blue vacuum hose is off, where that comes? Under steerin column.
Also something happened, main electric of car is gone, no lights on dash. Only headlights works. Is there main fuse somewhere?
What is box in drivers side under hood where is rubber button and "start"?
1970 Coupe De Ville//Cessna 172
I have a 70 so it may be different. If I remember correctly, coming off the starter where the positive cable connects are 3 wires with fuseable links. One goes to the fuse block, 1 goes to the headlight switch, and I forget where 3rd goes. You have probably blown the fuseable link to the fuseblock. I can't look it up right now because we are looking at moving and everything is packed. Look down by the starter and you will see them. The links are large round things on the wire itself. See if one is broken and/or deformed.
Jeff
74' Coupe de Ville
Discussion Starter #13
Thanks! And i need replace it for same or can i but normal wire with fuse holder?
74' Coupe de Ville
Discussion Starter #14
I order new fusible links, 10, 12 and 14 just in case. Those are pretty rare in ny country.
74' Coupe de Ville
Discussion Starter #17
Now its time to replace push button start and main switch on/off type.
Ignition switch connenctions what i found on my 74chevy repair manual, didnt found clear cadillac version in google. Is that correct? Original wires are now in on/off switch and bush button, ignition switch is empty.
1 SOL 7 IGN3
2 BAT1 4 BAT2 6 BAT3 8 GRD1
3 IGN1 5 ACC 9 GRD2
Those are terminals which were in Chevy repair manual,
1. White/other color
2. Red
3. Pink
4. Red
5. Brown
6. Red
7. Orange
8. Dark green
9. Ground
74' Coupe de Ville
Discussion Starter #18
Didnt work, run position was in star position etc.
I regonized that rear glass is loose and off. Is it original with glue or only sealed by rubber?
I mean rear window of course.
74' Coupe de Ville
Discussion Starter #19
Where is vacuum neutral switch for parking brake? I looked under dash.
Is automatic level control tank in deep co drivers side fender, almost in frame?
Hood is now vad, needs adjust. Inch slots at window side, clonks and bounces. Where i adjust it? Sheet side, fender side bolts or ?
1 - 20 of 25 Posts
