1 - 11 of 11 Posts
Hello everyone I'm new here and want to thank you in advance. I purchased this car about 20 years ago and been sitting in mothballs sense. With this epidemic my son has been home from college and has been on my tail to get it up and running - he loves this big tank. We have been working on the engine getting it running and she purrs. Now for the electrical which I'm not good at in the least. I have been chasing my tail around trying to figure out why I don't have power to some of the fuses in the fuse box. I thought one side of the panel is suppose to have power all the time on each fuse but not the case unless I'm missing some fuse able link some were. The inside lights, hazard lights, horn, no parking lights, no back up. I have taken a jumper wire and attached it to a strip of orange wire like a junction box behind the head light switch and some of the stuff works. Still no back up lights - if I put parking lights on I have both front and rear but one light on left rear doesn't light and no plate light. I have checked bulbs they're good and to see if got power but do not. Could it be a bad head light switch ?
96 FWB
.......We have been working on the engine getting it running and she purrs. Now for the electrical which I'm not good at in the least. ........
About the easiest - quickest - cheapest - most personally rewarding and best 'impressing offspring, SO and friends' things you can do is get a Factory Service Manual for your car. You'll soon:
- read and learn all about any of what sound like single and combined electrical issues you're having. Wiring diagrams and component/system descriptions will have you mopping each and all the problem spots up as you build experience that you admit you're no good at. You'll also be saving big bucks, aggravation and most importantly time, dealing with future issues as they surface v. going to a shop - which you'll find is always the case with a 1/2 century old car left to itself 20 years.
Just with what you've posted I'd:
- buy every single bulb listed for your car in the booklet at the car parts store
-get a big tube of dielectric grease when replacing every bulb in the car.
-buy an ebay or online .pdf copy of the FSM
-even before it arrives, check, clean and re-anchor every ground you can find under the hood, in the trunk and underneath the car.
-for a car left anywhere 20 years without one of those airtight bubbles you've got between 1 and 50 wires eaten by mice, and likely at least one electrical component with an ant nest.
well your probably correct I have 2 manuals and I have replaced the bulb and put in dielectric. In the wire diagrams I only see 1 fuse able link in side the car which I find odd . I'm going to have to find all the grounds and clean them. I just can't figure why there is power to most of the fuses and not others . At first I thought the back of the fuse panel was rusted because the 4 bottom fuses are not working no power but they weren't. wire chasing is in my future .....
Well FTSS , I have been working on the wiring issue for the last couple of hour's and traced it back to the connection coming off the starter the connection was dirty cleaned them up and every thing is working. I have the back up light's ,plate light and left bottom parking light to take care of. I think the connection to the back up switch is dirty so I will tackle that tomorrow, I will also have to trace the plate light. My new water pump just got delivered so I will also be replacing that as well... Thanks for the input ftss....
When I purchased this car years ago I had no idea how the previous owner jury rigged this car. Well I have found out why I have no back up light's ,the previous owner jumped the neutral safety switch as it was broken. I also found out why no plate light because there was no bulb. I am hoping once my new safety switch is put in that the rear lower parking light on the drivers will work but I'm thinking I have to take it out and check the wire's we will see.
Well I just had the neutral safety switch delivered . The switch I purchased was not the same as mine. the one that was in the car had a vacuum attached to the back for the parking brake release .I had to take the new one apart so I could modify the new one, I took the back off the new one and attached it to the old back with the vacuum attachment. I also had to shave the tab so it would fit in the groove in the steering column All working now.... The only thing that isn't working is the lower rear drivers side paring light.. Would anyone know how to get the light assembly out??? Do I have to remove the bumper ??? I have been looking at it and that seems to be the only way unless someone can enlighten me.
1985 Eldorado Biarritz Convertible, Sable Black, HT4100
Hi Golden Hands, sounds like you've made some impressive progress. I know very little about your gen of Eldorado, but I was curious so I poked around a bit on the internet. Here's a video of a guy replacing his bumper on a 1972 Eldo. It exposes the bulb harnesses etc. Not sure that's what you're talking about, but maybe this will help:
Discussion Starter #8
Thanks Scotteldorado, That video is perfect thank you for the link t will come in handy. My son and I today went out and purchased a new driver's door because mine has to much rust to repair it so he bought it for me for fathers day what a nice kid.. while we were there I ended up buying new rear bumper end's as well they all rust up on the inside where they seem and the price was in the budget. I have to take the bumper off know to put the bumper ends on so I will be fixing that light also.
Discussion Starter #10
Well today me and my son took the bumper off to put on the new ends. Of course the bolt's snapped and stripped out and the bracket's holding the nut were junk. So I had to make new bracket's and put in new bolt's . Tracing the wire's and found it was in the socket it self for the parking light is no good luckily one of the new end's had the light assembly all is working now. First thing in the morning we will be putting the bumper back on and on to some other thing's we have to fix ( mostly body work that need's attention before new paint job). Thanks again!
1 - 11 of 11 Posts
