1 - 2 of 2 Posts
1971 eldorado 1999 deville
my water light is on in the instrument panel on the dashboard. radiator is full and also the reservoir. any ideas what the issue could be?
Something German S550, 69 Eldorado, 68 Impala, If I tell you the rest, well
Test your thermostat in boiling water, does it open all the way (the spring compresses) at the thermostat temp. If not get a new one. Check the temp sensor wiring, or could be the sensor.
Make sure you have circulation in the cooling system, water pump flow and it's not actually overheating. Having a infrared temp gun is a good tool for old cars, then you can check/verify temp of of the whole motor, heads, upper/lower rad hoses etc.
1 - 2 of 2 Posts
