69&78 coupe Deville, 91&94 Fleetwood brougham
I just purchased a 1969 coupe Deville, the dash isn't working, I don't have interior lights
And speedometer doesn't work. However headlights work as well as blinkers. What can it be? Thank you for your help in advance!
1970 Coupe De Ville//Cessna 172
Re: 1969 coupe Deville dash issues
What do you mean "dash isn't working?" When you say blinkers, do you also mean the blinkers on the dash? Do you have any idiot lights?
The instrument cluster could have a bad ground. I have a 70 and the dash lights are finicky. You have to turn the headlight knob back/forth to get the dashlights to come on.
Give us some more info, please.
Jeff
1970 Deville Convertible
Yeah, agree with Jeff, need a clearer description.
Speedo works off a cable going to the transmission, is completely independent of anything electrical. Do you have cruise control?
As far as the "dash not working", check the fuse box for burned out fuses. Check them with a continuity tester to make sure they are making a good connection in the fuse box.
Has the car been "monkeyed with"? meaning have prior owners done some "custom work", which could be the source of the "dash not working"? Sometimes its a challenge when others before you have mucked up the works. Hopefully it is a fuse.
Thank you for your responses!
The dash is out completely - dead. Idk why I thought that maybe the signals had something to do with the dash... Such a girl I know! Haha
I checked the fuses and they're good, and yes it had some custom work done prior to purchase. :confused: I will.try as Christian suggested. Thanks again.
2003 Deville base, 69 Eldorado, 68 Impala, If I tell you the rest......well....
Light bulbs, mechanical speedometer/works odometer also. Turn signal switch in column. Wires, fuses. Headlight/dash switch. Good ole troubleshooting.
77 CDV, 06 DTS III, 69 FWB
If all the fuses are good, it's possible you could have a bad headlight switch, or that the dimmer rheostat in the headlight switch is bad or needs cleaning. Check that the speedo cable is connected to the speedometer and the transmission. If it is, and the speedo still doesn't work, the cable may be broken or kinked. Does the odometer work? Also, check to make sure all the bulbs are present and good.
1969 DeVille convertible, 1967 Eldorado
I have a similar issue. The only light that works on my gauge cluster is the gen light. No other lights work. Not even the turn signal indicators. Fuses all look good. What else could it be?
