That is what I bought from Modernspare.com. It works great, and barely fits in the spare well diameter. OEM can't be any larger if it fits in the well.According to Lifespeed the spare size is 135/80R18 .
The ratio is between the standard tire and the spare, not between two different-sized tires. The spare is already smaller.That has a 2236 mm circumference vs the stock 18s with OE spec at 2173 mm. That is not a huge difference (~3%) and shouldn't cause fits with the ABS/traction control. What is the tire size on the spare??
If you insist on having a spare in your coupe, throw it in the trunk like we did in the olden days.Which is a design choice, not a necessity. And a bad choice.
That's what my question was getting at.The ratio is between the standard tire and the spare, not between two different-sized tires. The spare is already smaller.
I stand corrected, the oem size is 135/70/18.That is what I bought from Modernspare.com. It works great, and barely fits in the spare well diameter. OEM can't be any larger if it fits in the well.
That's what I thought too. Turns out skeeter the tow truck driver isn't nearly as convenient as you might think. Try it, you'll see.I got roadside towing for my tire issues. Who needs a spare![]()
Yeah, and wait until you are in the middle of BuFu and have an issue.I got roadside towing for my tire issues. Who needs a spare![]()
That is the wrong attachment. My fault. That is only a 25" tire. I apologizeView attachment 594758
It's not a 19" , but overall size is what's really important. You don't want 2 different diameter tires on the same drive axle. It would be fine for my 20s that stand at 27.6". OEM 235/50R18 was 27.3".
You want to be at less than 1% difference in height for an AWD
My spare stands at 25.4" and my tires stand at 28". After talking to my tire guy I've come to realize that I have no choices other then carrying a full size tire in my trunk. The spare tire compartment doesn't have room for anything taller then the original spare. To use a spare tire I'd need an extra 2.6", not gonna happen. I'll settle for AAA and will eventually buy another 19" wheel which I will just leave at home.That is the wrong attachment. My fault. That is only a 25" tire. I apologize
You've got one size wider relative to the OEM 245/45-19, which I think makes it 4.5mm taller due to the 45% aspect ratio. If you were local I'd let you try my slightly-larger-than-OEM 135/80-18 spare, might be enough to not trigger stability control.My spare stands at 25.4" and my tires stand at 28". After talking to my tire guy I've come to realize that I have no choices other then carrying a full size tire in my trunk. The spare tire compartment doesn't have room for anything taller then the original spare. To use a spare tire I'd need an extra 2.6", not gonna happen. I'll settle for AAA and will eventually buy another 19" wheel which I will just leave at home.
Taller is definitely better but even with your taller spare there is a 1.54" difference. I think that is still too much of a difference to make the car drivable. SMHYou've got one size wider relative to the OEM 245/45-19, which I think makes it 4.5mm taller due to the 45% aspect ratio. If you were local I'd let you try my slightly-larger-than-OEM 135/80-18 spare, might be enough to not trigger stability control.
I'm about to uprade wheels and tires to 245/45-19 and am expecting the spare to work with the factory tire size and Modern Spare.
