1 - 20 of 24 Posts
08 STS V, had 06 V6 STS
I was browsing the autotrader site today and I found an 07 sts v8 with 18' oem wheels with 6lugs. In the picture it appears to have V brake rotors and calipers but is not a V car. Has anyone seen this option on a non-V car. I certainly haven't looked at any new Cadillac's since they are out of my tax bracket so I didn't know that was an option... Nice car with less than 7k miles for 29k.
'95 Fleetwood Brougham and '15 CTS
The "performance handling package" I think is what it's called. Was available on my 09 STS so I presume earlier years too. Came with summer tires, upgraded brakes and wheels (basically STS-v wheels, 6 lug). That's my guess as to what you're seeing.
2005 STS4 1SG w/ HUD-ACC
question? are those European Cadillacs. I have the top of the line 1SG with the performance brakes and I still have the 5 lug rims.....whats up with dat?
2006 STS 1SG & 2007 STS 1SE
I thought that option was only available on domestic models 2008 & after. I'm pretty sure only foreign market models had this 2005-2006.
05 STS4
It was available since day 1 roll off of the STS to my knowledge.
1SG has HEAVY DUTY brakes RPO JE5 the summer handle package had PERFORMANCE BRAKES and summer tires RPO J56.
Discussion Starter · #10 ·
Well, I'm not too great at computers so I couldn't figure out how to link it but here is the Auto Trader id # AT Car ID: AT-118FAE25 It's a So Cal car 91801 zip code.
Discussion Starter · #11 ·
http://www.autotrader.com/fyc/vdp.jsp?ct=c&car_id=294628901&dealer_id=66925&car_year=2007&doors=&systime=&model=STS&search_lang=en&start_year=2007&keywordsrep=&keywordsfyc=&search_type=both&highlightFirstMakeModel=&distance=75&min_price=&drive=&rdm=1299723360226&marketZipError=false&advanced=y&fuel=&keywords_display=&sownerid=563901&end_year=2012&lastBeginningStartYear=1981&showZipError=y&make2=&certified=&feature9=navigation&engine=8+Cylinder&page_location=findacar%3A%3Aispsearchform&body_code=0&transmission=&default_sort=newsortbyprice_DESC&max_mileage=&address=92530&color=&sort_type=priceDESC&max_price=35000&awsp=false&seller_type=d&make=CAD&num_records=25&cardist=53&standard=false"]http://http://www.autotrader.com/fyc/vdp.jsp?ct=c&car_id=294628901&dealer_id=66925&car_year=2007&doors=&systime=&model=STS&search_lang=en&start_year=2007&keywordsrep=&keywordsfyc=&search_type=both&highlightFirstMakeModel=&distance=75&min_price=&drive=&rdm=1299723360226&marketZipError=false&advanced=y&fuel=&keywords_display=&sownerid=563901&end_year=2012&lastBeginningStartYear=1981&showZipError=y&make2=&certified=&feature9=navigation&engine=8+Cylinder&page_location=findacar%3A%3Aispsearchform&body_code=0&transmission=&default_sort=newsortbyprice_DESC&max_mileage=&address=92530&color=&sort_type=priceDESC&max_price=35000&awsp=false&seller_type=d&make=CAD&num_records=25&cardist=53&standard=false[/URL]
2014 XTS V-Sport Platinum
That is a sweet deal...basically brand new with HUD/ACC and 1SG for under $30K...
OH FIVE STS V8
All of you "supposedly know it all" please don't assume and give a wrong answer! Do your home work first.
2007 N* STS-4
The Performance Handling package, RPO code PCZ, became available in 2008 for V-8-equipped rear-wheel and all-wheel-drive models and V-6-equipped rear-drive models. This package includes 7 spoke 18 x 8.5-inch 6 lug aluminum alloys, chrome optional, fitted with new P255/45R18 Michelin Pilot Sport summer-only tires.... STS V uses 10 spoke 18 x 8.5-inch front and 19 x 9.5-inch 6 lug aluminum alloys. Fitted with P255/45R18 front, and P275/40R19 rear, Extended Mobility – Pirelli tires.
Also includes Four-piston caliper Brembo brakes, RPO code J56, with front rotors measuring 355 mm x 32 mm and 365 mm x 28 mm rear rotors to provide enhanced stopping ability. All four rotors are vented.... Same as the STS V.
StabiliTrak with active front steering...active front steering available only on V-8 AWD.
Aluminum Strut Tower brace, V-8 and V-6 STS specific.
Stabilizer bars, hollow 33-mm diameter fronts, hollow 24-mm diameter rears on AWD and hollow 19-mm diameter rears on RWD. The hollow 36-mm diameter fronts are STS V specific but will mount on the V-8 STS.
And like I stated above, those are the 7 spoke 18" wheels that were also used on the CTS V....Anything else you want to be schooled on?
08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
The build sheet for this car shows:
Model: 6DC29-2007 STS V8 RWD/AWD 4 DR
1G6DC67A270157990
LH2 - 4.6L NORTHSTAR V8 VVT ENGINE
P56 - PERFORMANCE BREMBO BRAKES
PCZ - PERFORMANCE HANDLING PACKAGE: *18" ALUMINUM CHROME WHEELS *P255/45R18 SUMMER ONLY TIRES (REPLACES STD/OPT WHEELS AND TIRES) *PERFORMANCE BREMBO BRAKES (TIRE SEALANT & INFLATOR KIT IN PLACE OF SPARE TIRE)
P73 - 18" ALUMINUM CHROME WHEELS
QAF - MICHELIN PILOT SPORT TIRES, SUMMER ONLY, P255/45R18
P73 Is a Chrome 18 x 8-1/2" 7 Spoke, 6 Lug wheel.
It would seem the performance handling package was available in 2007 non-V series vehicles.
1 - 20 of 24 Posts
