Hello, I was wondering has anyone tried to put 20 inch rims on their 2014 CTS sedan. I would also like to know if anyone has put CT6 (item number 84033366) 20 inch rims on their 2014 CTS sedan.
What size tires did you use? I was told by a rim shop to put 235/35/20 tires on. They said they would work. What do you suggest?I did on my 16 CTS with CT6 20 inch wheels
What six tire did you use?Did not require spacers and have never rubbed once.
What size are the tires? And where did you get the center caps? I got the same ones but they’re starting to color fade from rainI just put CT6 20x8.5 wheels on my 2019 CTS. View attachment 587353 View attachment 587353
Did your spacer come with a lip on it or without a lip? I look up the spacer company that you provided. Was looking at the 5mm spacer but did not know if I need the lip?Well if you do get spacers look into this company. They make some awesome spacers. They can pretty much make whatever you want. US Wheel Adapters, Wheel Spacers & Hub Centric Rings [Best in US]
What size tire did you use?What six tire did you use?
