1 - 2 of 2 Posts
Hello everyone, came here looking for help. Have been stuck on this problem for a few weeks and wondering if anyone has any ideas.
Airbag Codes:
B1019 - System Configuration Error (Symptom 00)
B0098 - Active Switch Circuit Short To Battery (Symptom 01)
B0084 - Front End Sensor 2 Incorrect Component Installed (Symptom 3A)
B0083 - Front End Sensor 1 Incorrect Component Installed (Symptom 3A)
B0081 - Passenger Presence System 1 Incorrect Component Installed (System 3A)
B0080 - Right Front Seat Position Sensor Circuit Short to Ground or Open (System 06)
B0079 - Left Front Seat Position Sensor Circuit Short to Ground or Open (System 06)
SDM has been replaced and programmed twice.
My Ethos scanner allowed me to update BCM with new SDM code, however, when I click on "Set Up New SDM" on my scanner, it doesn't seem to be working.
SDM had a connection problem with one of the connectors, when you wiggle the connector a bit, it would lose connection. I took apart the connector and tightened up all of terminals a tad bit, this seems to fix the loose connection issue but no change with codes.
Any help at all would be extremely appreciated.
"SDM" is the airbag module for those wondering.
1 - 2 of 2 Posts
