I have always used 10W-30 Mobil One synthetic on my 94' Deville Concours. I recently tried using 15W-50 Mobil One for the summer season. I did this on my 97' Seville with no problems. In fact it was noticably smoother at highway speeds during the summer months. On the Deville, I keep getting the "check oil level" message when it is not low. In the most recent situation it was only down half a quart. Am I hurting anything by running 15W-50? I assumed that the 97' and 94' Northstar engines would respond the same to the different oil weight. Has anyone else experimented with this?
The message is not from the oil. It is a dirty connection or a failing sensor. Personally I'd stick with what the factory recommends.
:thepan: 15W-50 is good for commercial diesel or 454/455 c.i. boat engine service. (Is the jug labeled CC/CD?) It is not good for automotive engine service, especially in Michigan, and will probably cost you a mile or so per gallon as well as starve the engine for lubrication at cold startup. Trust Ranger: Go with the factory recommendation.
Turned out to be a bad connection. Light corrosion on the female end of the oil sensor plug. It has been cleaned and everything seams to be fine.
As far as the oil, I liked the 15W-50 in the Seville in the summer, especailly on the highway. I do a lot of driving "up north" and to the west side of the state (2-3 hours one way) and lately the weather has been unusually warm. The oil I'm using is 15W-50 Mobil One "Performance Formula." The spec says API CF/ API CD. Maybe it's overkill, if I don't like it I'll change it back. Eitherway, I'll be changing it back in mid September anyways before it cools off.
Sedan de Ville, CTS
I would also worry about the 50 W going back down into the oil guides quickly enough. Engines 40 years ago had tons of room then and there. Today, engines are more highly refined.
