Anyone got a pinout for the headlights, I'm modifying the wires coming off the Diode Dynamics 80mm switchbacks so I can install these super clean without the use of cable connectors (I hate these things cause they cut the wires). Will make a detailed picture how to using connector parts from pololu.com.
Need:
White: White Low Power wire for night mode 50% brightness
Red: White High Power wire for DRL, 100% brightness
Yellow: Amber Signal wire, double brightness to trigger flashing amber mode (dims if powered more than two seconds)
Black: Ground
Thanks all!
Need:
Black: Ground
Thanks all!
