2006 Cadillac CTS [] 2008 Cadillac DTS
I just installed a new Camshaft sensor for a P0340 code, and noticed the check engine light came back for the same code... Does it need time to relearn? Has anyone else had a similar experience...
Thanks,
You could have a wiring problem. Do you have smart scanner to watch the data from the Camshaft sensor. Camshaft sensor doesn’t need to be learned.
576742
I do not have a scanner, but I did replace the part with a cheap Chinese made one that actually caused starting the car to be worse. Im actually going to a pick your part to get a new front bumper, since im there I might just pull a sensor there and see if it works, and if it doesn't that will be my next point of attack. Thanks for the information
2008 DTS
I had all kinds of lights on when I had the rear valve cover gasket replaced on my 08.Camshaft being one of them.Turns out they snipped some wire back there that caused all the havoc.They fixed it and all is well.
