1 - 9 of 9 Posts
2007 Cadillac Escalade 2wd with 60k original miles
VIN: 1GYEC63827R295409
Clean title In hand shows 49k actual miles when purchased In 2012
Black on black fully loaded navigation, cooled seats power running boards on stock 22” oem wheels
Factory GM 14 bolt posi rear differential with 3:42 gears
Level10 built 6L80E with PTC stall converter drives like stock have receipt $4496
Removed & replaced L92 engine with a LS3 with only 22k miles with less than a thousand on boost have receipt $3500
Twin Precision 6262 ceramic ball bearing v-band inlet/outlet .82 turbos
Twin TiAL MV-R 44mm waste-gates discharge vented back into exhaust
Stock manifolds modified with 3” v-bands along with aftermarket 3” v-band y-pipe to a Corsa sport exhaust no cats but nice and quiet sleeper when cruising
Treadstone TRTT9 Twin turbo front mount intercooler with 3” & 2.5” aluminum piping with t-bolt clamps
TiAL Sport Q 50mm blow off valve vented to atmosphere
73lb FIC fuel injectors with a kenne-bell boost a pump
Labonate motosports methanol injection kit with gallon reservoir with visible activation light on dash
Turbosmart Dual stage electronic boost controller inside with digital boost gauge low 6lbs high 10lbs @ touch of button
Innovate Motorsports AFR gauge mounted on dash with data logger
Tuned by Jeremy Formato of Fasterproms
Made 617rwhp & 605rwtq with junk L92
Has gone 11.9 in 1/4mile with junk L92 In full street trim/weight on 22’s vids on youtube
Will definitely make more If wanted have only run 6lbs on Ls3 still on Jeremy’s L92 tune
Eibach Pro Kit lowering spring brand new In the box along with other misc. stock parts
Sure there’s more any questions just ask..
20K FIRM FIRM..
Kevin
Located In Miami Lakes Florida
moderator edit: to contact this member about the Escalade for sale, please use the private mail system on the forums. To do that, click your avatar in the upper right and choose "Conversations". - Byrdman
Twin Turbo Escalade Sleeper
591994
591995
591996
591997
591998
2003 Deville Base
Really bad idea to post your phone number or email. Please use the private message system on the forums.
Do you supply a 4 year bumper to bumper emissions-legal unlimited use warranty for the entire vehicle? Otherwise someone's dumping about $21K into a 14 year old federally illegal mechanical potential time bomb.
2003 Deville Base
Good question. I'd like to know as well. In our state that would never pass inspection. LOL
Please do your own research..
I live In Florida No emission or safety inspections.
Want a warranty go buy brand new 2021 for 100k!
Submariner409 thank you for your service.
1 - 9 of 9 Posts
