1 - 14 of 14 Posts
Please help battery just started these problem going dead but took it to go get the battery checked they said it was good i give it a boost and its good it starts by itself afer that but in the morning needs a boost again thanks for your help
2012 Escalade, 2014 SRX
As said if you still have the stock Delco get rid of it and your problems will be over, Escalade's are tough on batteries to start with, and the factory battery is average at best
Premium Member
17 XTS Platinum V-Sport; 17 Buick Envision AWD Turbo; 10 Lincoln MKS AWD Twin Turbo
If my truck was not leased, I would absolutely get a new non-DELCO battery. Delcos failed within the first 1.5 years on my prior 06 SRX, 07 Lade, and after 2.5 years on our 01 SLS. All replaced under warrantee, so that is why I have not looked at different battery manufacturers....yet.
'07 Escalade ESV AWD
Another battery problem related post...shocking! (not)
hcvone's thread about the dual battery conversion should be a sticky at this point, no?
I'd post a link to it right now but I'm having trouble finding his dual battery DIY instructions. Very cool, very thorough...
escalade
i was having this problem and took my lade to cadillac. my truck died once and the radio date and time kept reseting. took it to cadillac and they redid all the grounds. now i havent had any problems...
I would have it checked for sure, but I can tell you after 30 plus new GM cars/trucks I very rarely get more than two years out of a stock Delco battery
I will find it and put a sticky on it. :)
Discussion Starter #10
did u find the link
19 CTS-V, 17 Escalade, 88Corvette,71Corvette
My 07 ESV had similar issues. The dealer warranteed it so it was free. they also said 07 builds didnt get a strong enogh battery. The new one has more cold cranking amps.
My 09' has the same battery as my 07's came with, I know because I pulled it out and replaced it last week when I put the dual batteries in. :crying::banghead::bomb:
Premium Member
I don't think that is accurate. When they replaced my 07 battery in late 08, it was an identical replacement.
1 - 14 of 14 Posts
