2015i Escalade
Hi all,
Have an 07 Escalade with 35K on the ODO. Went to pull it out of garage and nothing, no crank, lights on ok but not even a click. Tried remote start and nothing either. Battery is ok, at least it appears to be. Tried it a few minutes later and started but ran rough. Any ideas? Read all posts, looking for new ideas.
Stosh
I had the same problem on my '07 Silverado, and '07 Escalade. Dealer changed out the battery on both and they were fine.
How long has it been sitting for? Battery original? When you tried cranking it, there were no noises coming out of the engine bay? Might be a bad starter, but I'm curious as to why it would run rough. No engine lights?
check the voltage when its running if its under 12v then it could be a bad battery or alternator and it will cause it to run rough.
2015i Escalade
It has service engine soon light, no noise at all. I will look it over tomorrow for obvious things, corroded cable, check voltage etc let you know what I find. Thanks for the the feedback.
Stosh
2015 Escalade and 2018 CTS-V
Mine did this a while back. Took the cover off the starter and gave it a light whack. Started right up and never did it again.
2012 Escalade, 2014 SRX
If it has a delco battery replace it and your problems will be gone, also as said check the cables, some times they look fine, but careful inspection will show damage
