1 - 16 of 16 Posts
2007 Escalade
I have struggled with this since I have owned the truck. I have replaced all the belts, idler pulleys, and tension pulleys. I am using Gates belts. I have eliminated the squeal on the main serpentine belt. I can spray belt conditioner on the AC belt, it will stop screaming until it wears off, then start up again. Moisture or rain makes it worse. It is worse in the morning on cold starts. Any one got any solutions? I'm wondering if the AC compressor is going bad... it works great though. This is driving me crazy.
2007 Cadillac Escalade Base
You may need to replace the A/C clutch? Have a shop or mechanic take a look at it, sounds like the bearing associated with the A/C clutch may be shot and is causing your noise issue from that location.
2007 Escalade base
If the noise is only coming from the AC belt then i am sure you need to replace the small tentioner for that belt. It is a very week spring in that unit and i have replaced many for this problem. Good luck
2007 Escalade
Discussion Starter · #4 ·
This will be the 2nd time I have tried a new tensioner. I am going to try a different brand belt this afternoon. I hope this fixes it. If not, I will be looking at a new compressor. This truck will be brand new by the time I'm done.
2007 Escalade
Discussion Starter · #7 ·
On the main belt (non-AC) --- I just replaced a 6 month old Dayco belt with a brand new Gates belt. The Gates belt made it two weeks and started squealing. All the pulleys feel fine and everything looks to be aligned... this is driving me crazy!
PS - The AC belt is doing fine.
DHS, 2007 ESV
If you turn the climate control off, does the squeal change? What about if you turn on the defogger? If it is worse in the first case, it could be a bad A/C clutch bearing. Otherwise, it could be the compressor itself.
2007 Escalade
Discussion Starter · #10 ·
Well, the Goodyear gatorback worked for a few months. It was raining this morning when I started the engine, then came that awful chirping/belt slipping noise. I have replaced both tensioners and idler pulley. Everything looks to be in alignment. This is about to drive me crazy. I'm tired of buying belts every 2-3 months.
I am going to try taking the belts off and cleaning them with soap and water to see if something is on on it.
2007 Escalade
Discussion Starter · #14 ·
I will try a Bando next. I reversed the direction on my current belt and it stopped the squeal until it wears that side out. People say that means a pulley is out of line but I'm not seeing it.
I will have to try this also, seems like whenever it rains I hear a belt or bearing noise but when it is completely dry out and I haven't sprayed WD40 or anything it's quiet. But as soon as I spray WD40 on the pulleys or belt the noise comes back for a few days.
· Super Moderator
2010 Platinum Escalade, 1996 Fleetwood Brougham
WD-40 is a lubricant. If one applies some form of a lubricant to an item such as belt that is not supposed to slip, it will probably slip. A slipping belt is a noisy belt. I wouldn't recommend using such a product for that purpose. JMHO...
1 - 16 of 16 Posts
