1 - 13 of 13 Posts
07 Escalade
Is any one running a bigger tire on the oem 22" wheels? I'm thinking of running a toyo a/t tire but want to go up to a 305/40/22.
1996 Cadillac Deville
305/40-22 is half an inch smaller in diameter than the stock tire. Hence, your speedometer and odometer will be slightly off.
Not sure about clearance in the wheelwells, though.
07 Escalade
I have 305/45/22 Nitto's on mine. Looks good, rides good and only rubs in the rear as I leave my subdivision.. The angle of the exit I assume is the culprit. Passenger side gets compressed while drivers side extends... Guess I could hit the exit straight or slow down... but I dont..lol
2008 CTS4, 2011 EXT, 2002 Avalanche 2500
I run 305/40/22 they are a little wider which I like. Not much difference in height compared to 285/45/22 that came on my truck
2010 Escalade,05 F150, 05 G35coupe
I agree ride is awsome but I have major rubb issues on my left i forgot name of inside but is ribbing badd on the black plastic No choice but to cut or take it off!!!
07 Escalade
So i went up to a 305/40/22 tire on the stock escalade wheels. Yes it rubs but after a little trimming on the back inner fenders its got a nice stance.
Escalade
Im sitting on 26s and thinking about going to 28s just wanna know if anyone is having issues with anything bigger than 26s
2008 Escalade EXT
This might sound weird. I'm running 305/35R24 offset 30. At stock height, I had lots of rubbing. I think it was hitting the rear of my wheel well and side runners. After lowering it 2". I have absolutely NO RUBBING.
08 escalade ext / 04 xlr roadster
I just had TOYO proxy 2 305/40/22 tires installed and have no rub issues ( stock chrome rim ). They are about 1/2" overall or 1/4" less in radius meaning 1/4" in height. They are about an inch wider and handle much better than stock 285/45/22. There is a slight loss in gas mileage overall. Wanted the 305/45/22 tires but they would rub. Had them ordered in and mounted on one rim to test and there would be a rubbing issue with full lock turn. Want to see how they handle in snow. very impressed with TOYO tire
1 - 13 of 13 Posts
