2006 CTS Luxury
So i took out my fog lenses a while back to mess with tinting. Wound up with success and then removed the other to continue. Thinking that if i just took one apart my memory at putting the other finished one in right back in its original place easier. Well it did its so simple compared to how i thought it was going to be. But now that i have put my lenses back in they look all retarded. Can some one please tell me what i did wrong?
Bottom left
Top Right
Top left
I have the plastic side plugs in the houseing in the lens on, and the rubbery fitting on, with the screw through it, and the other 2 screws lightly screwed in, and it somehow looks like this.
06 CTS Sport/Luxury package
Here's a stupid question. I didn't understand how you took them out, so I am just going to ask these questions...
When you took them out, how did you do that? Did you take out the three 7 or 8 mm bolts? As one of them are shown above, and that's it? Or did you actually take of the mounting bracket from the fog light housing as well?
If you took the fog light house off of the mounting bracket (stupid question here) did you accidentally swap the fog lights for the other's housing?
I am about to tint mine tomorrow, so if you could answer this for me... Did you use a heat gun to get them nice and smooth like that? I've asked a local shop and they told me that I would be insane to use a heat gun on the piece of plastic. First thing that pops in my mind are people actually putting these in 350deg ovens to separate the plastic pieces.
KOT
2006 CTS Luxury
Well i worked on one lens for about a week lol just messing with tints because ive never messed with vinyls before. I bought a plastic squeege you can just use like a plastic credit like card. But theres this spray adhesive i use that i love that makes the job 20 times easier called Rapid Tac Application Fluid. I think Rvinyl sells them.
Basically what i did was i bought a tint kit for the headlights and fogs, in the darkest tint i could find online. Since the lens of the fog light is actually bigger than the opening in which you can see the lens through, its hard to mark where to put the vinyl. Especially since its not gonna be the size of the whole lens. So i just applied the headlight vinyl to the fog light, took a razer blade and cut a square frame to take off the excess vinyl. Dont worry you wont see the scratches anyways. Then i bought these other vinyl tint covers i believe from Rvinyl.com. They are smaller than the cut out vinyls i made, so i just centered them as best i could on the lense, with the rapid tac again.
If you get any creases or wrinkles try to slowly stretch the vinyl to fit the curved surface that is causing that crease, or try to squeegee it away but dont make it worse by applying too much pressure. You can always take both vinyls off if you mess up and just try re applying them.
I had to use a blow dryer to get a bubble out of my break light tint, but be careful its easy to mess up the rest of the vinyl if its too hot or you heat up the wrong area.
Taking out the fog lights isnt that hard. Just take out all the plastic pins on the wheel well cover and then you can see the lens the bulbs the housing and there will be a rubber part that fits between the bumper the lens. There are two more plastic pins that are extremely hard to get out with out using a screw driver and another finger to pry them out or just using pliers. They are on either side of the housing holding the lens to the housing.
Then there are 3 screws one in front of the lens in the bumper, one under the housing of the lens, and a 3rd further in the towards the center of the car thats kinda hard to find, just feel around for it. Also remember turning the wheel of your car helps make this process easier of course 8).
After that all thats left is to unplug the bulbs and take it out. I actually left the 3rd screw in the housing on one of mine and just swiveled it over and pulled the lens out. Just be careful because you might wind up with the problem im dealing with im just in too much pain atm to go try and mess with the adjustment screw.
Hope this helps, feel free to ask away 8)
2006 CTS Luxury
Discussion Starter · #6 ·
Wow i type all this stuff up to edit my last post and by the time im done i can no longer edit it and ive lost everything i wrote.
Basically, I know it is the correct lens and enclosure, i can go into detail. But i know as a fact that i put the correct side lens and enclosure altogether in the car
Now im not sure how the adjustment screw works, but since the lens is stuck in the enclosure by two of those plastic pins plugs then i dont see where the room for adjustment is. All i can do is move the screw up and down and it looks like either way will just be putting unneeded pressure on plastic parts.
