Recently purchased an 06 DTS Performance. About a week ago, noticed voltage was reading higher than usual, charging at 15.0-15.1. Within a day or two, the battery was dead. Took a jump easily and on short trips there was no issue other than the voltage reading pegged at 15.0+.
Overnight, the battery would drain and need a jump in the morning. Replaced the battery and it ran high (15.0) for a day and then seemed to settle in around 14.4 which I consider normal. This morning, second day with new battery it is charging again at 15.0-15.1.
Upon start up, it reads around 14.0 and gradually works its way up to 15 volts. I would think it would be the other way around...after start up, it would charge at a higher rate to bring the battery to normal level and then gradually decrease to the low 14 volt reading.
I can assume I have a drain/short somewhere but is this a normal reading for the voltage?
