1 - 11 of 11 Posts
05 ESV
Brand new to this forum so I apologize if this has already been posted.
My 2005 Escalade ESV has issues with ONLY the front AC/heat blowing. It trickles out, but will work only when it feels like. The rear works just fine.
Any helps is greatly appreciated!
03 cadillac escalade
Ivabgn said:
Brand new to this MB so I apologize if this has already been posted.
Are you talking about water under the truck when the ac is running if yes then that is normal
Also welcome to the forum
05 ESV
Sorry, I should have been more specific. The blower itself on the front AC/Heat only blows on occassion. The rear AC/Heat blows all the time as it should. I am curious as to if it is the front blower itself that needs to be replaced or if it is a relay. Thanks
Blower control module needs replacing in the front not the blower
05 ESV
WOW thanks! What a great resource you are to have. Can you tell me where it's located and how difficult it is to change out? Thanks again!
Passenger side under the dash
Remove the kick panel(three screws)
And it is next to the blower(if not follow the wires from the blower) on the bottom far right
2003 Cadillac Escalade
Welcome, I myself am new as well and have found quite a bit of information to be helpful. While you have an ESV, I have I guess just the standard model AWD.. I had this same problem (amongst others) for quite sometime until I finally today purchased a Blower Motor Resistor. I never figured out why it was doing it until I messed around with this part which is in the black casing underneath your glove box. When it wouldn't blow, moving the resistor made it come on. Fairly cheap part. Hope this helps!
05 ESV
Discussion Starter · #9 ·
Thanks for your help. I'm going to try and find the part tomorrow and change it out. I just hope someone has it in stock.
05 ESV
Discussion Starter · #10 ·
Thank you to everyone. Worked like a charm and only cost me $169 and 5 minutes of time.
1 - 11 of 11 Posts
