So just curious what the best harness is I want to keep factory amp want to keep everything but OnStar I'll keep it if I have to but idc and I'm running a line converter now to my subs and I hooked in behind cd changer to the sub wires and it just doesn't sound good at all should I be hooking in elsewhere or what an I doing wrong also does anybody know if I can keep rear entertainment if I put in aftermarket stereo thanks
2006 Escalade AWD w/DiabloSport tuner,Jet Performance throttle body/MAF,Airaid MIT
I use a PAC interface that retains Onstar, the stock Bose amp, and key/door/rear collision sensor chimes. The PAC module also allows the rear entertain sound to be played through the aftermarket radio AUX input.
I have this unit installed in 2006 Caddy.
Sweet same thing I ordered today I was kinda hoping for a cheaper route but if it's what I need it's what I need thanks
No problem. The unit is pricey, but it works. Steering wheel controls and all. My Sony aftermarket radio works like the stock radio, but with better sound.
Ok thanks I already ordered the expensive one but maybe I'll return if I can thanks again
