Is there a fuse for the headlights? if yes, where is it located. Before I buy a new expensive low beam bulb to replace the left headlight, I wanted to check the fuses first
2006 Cadillac Escalade EXT
In my owners manual for my 2006 EXT it says that in the underhood fuse block there are fuses for Left Hand High Intensity Lamps and Right Hand High Intensity Lamps.. I am assuming this is what you are looking for.. Check your owners manual for the diagram.. Its labeled LH HID and RH HID.. I am assuming those are what you are looking for...
Also a cheap way to find out if its the bulb you can simply swap the bulbs.. take the working one out and put it in where the burnt out one is.. If it turns on then its your bulb.. If the light doesnt turn on its either the fuse, ballast, wiring, etc...
2012 Escalade, 2014 SRX
Your truck is still under warranty right? They will replace the bulb if it is blown, many times the ballast goes even before the bulb, this happened in my 03'
