1 - 20 of 57 Posts
2005 Escalade AWD 6.0l.
80 K miles. I had a ticking sound, like a lifter?, coming from the front right engine compartment. It turns out that there were 3 exhaust manifold bolts broken off on one side and 1 broken on the other side. The mechanic knew what the problem was before he even heard it or lifted the hood. He says it is a common problem with the 6.0l engine. I have owned many vehicles and have never had a single manifold bolt broken! Does anybody else have this problem? Is there a recall, published or secret, on these things? This shouldn't happen, right?
Thanks for any ideas.
It is still a work in progress. I,ll let you know. I've also contacted Cadillac and waiting to hear.
Escalade EXT
You guys got my attention.. I have an 05 With 75,000 miles on it. Hope I dont have this problem. Keep us updated if GM does anything about it.
It's an easy thing to check. Even if you don't hear an exhaust leak, lift the hood and use a flashlight to look at the manifold bolts. They're not just cracked, they're gone! First estimate is $300 - $400. I'll know more in a couple days and will let you know if I hear from Cadillac.
Jeff,
See, I didn't know Customer Service monitored this site? I contacted Cadillac through the main website a few days ago and haven't received a response or case number, yet. I tried to send a "private message" to you but this system wouldn't let me. Something about spam worries and not enough time in grade.
Regards,
Bill Blackburn
Discussion Starter #8
Okay, here are some results with my "bolts" problem. A total of three were broken, two on one side and one on the other. It looked as if the heads had just popped off the bolts. This shouldn't happen. I figure they were either defective materials or over torqued when applied. It cost me $260 for gaskets, bolts and mostly labor at my local mechanic. Cadillac never responded to my website inquiry so I called and filed a complaint on the phone. (for Jeff Morris, my case # is 71-853860213) They were not helpful! Having an exhaust manifold spontaneously come loose may be a serious safety issue. It presents both a fire and CO hazard. I'm not sure of my next step. If a few of us have this problem perhaps we should contact the NHTSA? They have a website for reporting such problems, http://www-odi.nhtsa.dot.gov/. What do the group think?
Bill
ESCALADE
Checked mine tonight, both sides have the rear ones broke off. Mine dont leak but the bolts are gone. The money cadillac gets for these things they should do something!!!!
Discussion Starter #10
Esky,
Yours don't leak, yet! How many others of us, with these engines, are driving around unaware that the manifolds are hanging on by a thread? It only takes a few minutes to file a complaint with the NHTSA. http://www-odi.nhtsa.dot.gov/
Regards,
Bill
Discussion Starter #11
Esky,
Regards,
Bill
Escalade EXT
checked mine today. I have 2 that are broken. one on each side in the very back. GM needs to do something about this problem. Mine is not leaking that I know of yet. But it looks like all the other ones are going to break at any time.
Discussion Starter #14
OK, ksescalade05, cadillactruck05, esky02, and I all have the manifold bolts failure! I'll bet there are any number of other GM 6.0l owners who have the same problem but haven't checked. Seriously, guys, it sounds just like a sticky lifter, or makes no noise at all. Go look at your vehicles! If you know any other GM owners, with the 6.0l, warn them. I did check the Chevy site and readily found several "manifold bolt" problems. Again, I have had no response from Caddy. (This is where Jeff Morris might want to weigh in?) I'll bet GM got a bunch of bolts, probably made in China, that were sub-standard. Which reminds me, if you have your bolts replaced, save them in case the NHTSA needs to check them out. Have your VIN handy and go to http://www-odi.nhtsa.dot.gov/ and file a complaint. It only takes a few minutes and, collectively, we might get some results. I had a 2000 Suburban, 5.3l, with 160,000 miles. The manifold bolts were just fine. I have never had any vehicle where this has been a problem!
Sorry about the double post, earlier.
Regards,
Bill
2003 Escalade
just checked mines, and i have 4 missing. Hard to say what happened to them because this motor has been replaced before. I'm heading to the junkyard monday and see if i can get some bolts off a tahoe/yukon that'll fit. Mines isn't leaking.........yet.
Discussion Starter #16
Hey d3apool,
Sorry to here that. This is not an easy job. You'll probably have to pull the manifolds to replace them so you might as well replace them all. Good luck!
Bill
2003 Escalade
Hey d3apool,
Bill
thanks, i just filled out a complaint, even tho i'm not sure i lost my bolts or they just weren't put in when the motor was replaced. What else was going on with your engine besides the ticking sound?
Discussion Starter #19
d3, The ticking sound actually starts to sound like an exhaust leak, after a while, especially when you first start up. I checked the links you posted and will probably join so I can post what we Cadillac owners have experienced.
Regards.
2002 Escalade
Just ran into the same issue on my '02 at 125,650. Those of you who know me, know my truck is impeccably maintained. Shop needs to replace the driver side manifold entirely, quoted around $900. Unreal. :mad2:
Based upon numerous responses on a number of forums and the video shown at the link below, I have filed a formal complaint with the NHTSA. (ODI: 10494361) I'm sure many of you have done the same thing, I can only hope that they will even read it.
Will GM Recall Broken Exhaust Bolts on Its V8's?
1 - 20 of 57 Posts
