2005 DHS. Seems to slightly speed up when I press the brakes. Can feel it slightly and it's annoying. Any ideas?? Also seems to have a largish clunky feeling sometimes when I speed up.
IPC
U1016 Loss of Class 2 Communication with VCM
U1000 U1000 Class 2 Communication Malfunction
IPM
B0429 Temperature Control #3 Rear Circuit Range/Performance
B1004 Keep Alive Memory (KAM)
PDM
B1913 Heated Seat Switch - Mode Input Shorted to Battery
U1714 Something about power window. All work fine.
B2507 - RF LAMP HIGH BEAM CIRCUIT Failure
Ok. I will check all the vac hoses this weekend. Will probably pull the throttle body and check for holes in the boot. Probably needs a good cleaning anyway. Preparing for coolant crossover gaskets in the future. Dealer that I purchased the DHS from recommended them being done. Been watching coolant levels like a hawk. No changes in 3K miles since I purchased it. So far so good. Engine has a very rough idle on cold and warm startup that goes away in a few minutes. No missfire codes showing. Maybe a plug replacement this weekend also.
