2005 Deville Base model
TPMS has been working correctly until I broke a valve stem off. Had to replace broken one with rubber stem due to cost issues. (Discount Tire wanted $60 for one. RockAuto was considerably cheaper.)
Bought 4 new TPMS from RockAuto. Didn't get AC/Delco, got Standard brand.
Went to Discount Tire to have them installed and balance tires.
They could not get them to be recognized by the vehicle. They tried; using their tool that looks like a scan tool (might even be a scan tool), a magnet, letting air out of the tire. All to no avail.
And, yes they seemed to be putting the car in relearn by turning ignition to on and holding the lock and un-lock buttons simultaneously until horn sounded.
After 45 minutes we gave up. I was watching, the only thing that I did notice was when going into relearn, the horn would honk once, but it did NOT give any indication that the car was in relearn on the DIC.
After contemplating this overnight, I tried to go into relearn again this morning. This time I double checked to make sure the tire monitor was turned on in the DIC, set the e-brake, held the lock & unlock simultaneously until horn sounds. No indication of relearn on DIC. I even tried holding the buttons till the horn sounded and then held the buttons again. Nothing happened, no horn or indication.
Also, there were no relevant codes.
The relearn process was successfully done 9 or 10 months ago when I got new tires in Oklahoma, can't go try that shop, I'm in Arizona.
Does anyone have a clue as to what has been missed, here?
