1 - 14 of 14 Posts
2005 Deville
6 disc changer in glove box comes up on screen (no disc loaded). I unplugged the unit in the back for 20 mins and plugged it back in and tried it again. Still no disc loaded.
Is there anything else I can try?
Thank you for any help,
Mike
Remove and install the disc cassette itself - it should pop out of its mount. Same process for the center console unit in my STS.
EDIT: "Changer" edited to "cassette".
I removed the two screws and pulled the changer to get to the plug in. Any other ideas?
with the changer installed - ignition on - radio on -
remove the CD cassette - and re-install it -
^^ Yeah, that. The cassette pops out with a simple button push - so you can change CDs. Sometimes the system will fail to recognize that the cassette is inserted - all you do in this case is to jog the system memory.
2005 Deville
Just gave this a try and no luck. Still get (no cd loaded). Any thing else to try?
when did it work last?
can we assume nothing changed since it worked the last time?
didn't change any stereo stuff -
didn't change any CD's in the cassette - etc?
strange that the cassette ejects -
and the radio recognizes the CD changer -
just doesn't "see" and CD's -
are these factory CD's or burned CD's?
did these discs work in this changer before? -
2005 Deville
Discussion Starter #8
I just bought the car. Every thing looks to be factory. The previous owner had discs loaded that they left in the car. When I hit the cd button to play it comes up no cd loaded. I did try changing out to my factory cd's , but no luck...
be sure the CD's are loaded correctly -
it's easy to load them upside down -
do the "supplied" CD's play in the single-disc radio CD player?
2005 Deville
Discussion Starter #10
I load them label side up, but I have tried them the other way also. The car doesn't have a single disc player. But the discs play in my GMC pickup truck, and in the home disc player.
what? - your radio does not have a CD player?
are you sure?
2005 Deville
Discussion Starter #12
It's got the nav system and then 6 disc changer in the glove box.
Would it hurt to pull the CD player fuse? I don't have a code to put in, will I need one?
2005 Deville
Discussion Starter #13
I was wrong, it does have a single disc player behind the navigation system. The single disc player works, but the 6 disc changer still doesn't. Anyone else have any other ideas to try?
just thinking out loud -
the changer obviously has power
because you can eject the cassette -
the radio has communication with the changer -
because the 6 disc changer comes up on screen -
andyou get the message no cd loaded -
sort of narrows it down to a defective cassette -
or a bad changer -
ALL the GM 6-disc cassettes are the same -
so - if you know someone with a 6-disc changer -
try your cassette in their changer -
and their cassette in your changer -
ebay is a good source for a used changer - ~$100 -
it MUST be from a 2002 and newer Deville or Seville -
GM 25740088
hmmmmmm -
just had another thought -
I wonder if it's possible that a disc is stuck inside the changer -
and wasn't returned to the magazine?
1 - 14 of 14 Posts
