Having some weird problems with my headlights. They work fine right this moment but sometimes when I turn the car on only one headlight will be on (low-beam, I think). When I push the hi-beam stick forward only the right headlight will be working. When I pull the hi-beam stick back, both hi-beams work. If I flick them rapidly back and forth I can get both hi-beams and both lo-beams working (not at the same time, just when I have brights on or off). Relay appears to be fine, and by "fine" I only checked if it clicks when brights are activated. I checked the bulbs and they're fine. I replaced them and still the same issue. What's my troubleshooting steps here?
Fuses are OK
Relays are OK (if clicking noise is indication of OK)
Bulbs are OK
Fuses are OK
Bulbs are OK
