1 - 15 of 15 Posts
2004 DeVille Base Sedan
I Know my Mode door Actuator is making Noise since last year, However It still moves the air up and down. Now there is a new problem i think there must be another actuator for temp that controls pass side sometime it blows cold but most often hot air. the passenger control lights up and shows blue but only hot air any info would be helpful Thanks
The codes are B0419 and B0429 #2 and #3 what part do i need thanks
Ron already supplied the correct part number -
here is a great HowTo - including pics -
NOTE - when removing the knee bolster - PULL IT STRAIGHT BACK - NOT DOWN -
there are small plastic guide pins that you'll snap off if you tilt it down -
regarding the MODE door actuator -
keep in mind that it moves EVERY time you cycle the ignition -
you already got the ONLY warning of certain impending DOOM -
when it fails - it is stuck in what ever position it was in last -
and you KNOW it's going to fail in the winter - probably on a Monday - during a winter vortex -
when you need the DEFROSTER - but it's stuck on VENT -
the MODE door actuator is ACDELCO 15-72654 - $56 - with free shipping -
here is a HowTo -
we found a few more tips to add - read these -
here is a HowTo -
Thanks Bass What a Nightmare on the Mode door Actuator install : (
One more Question so from what I understand there are 3 Actuator's under dash 2 that are buried and one on left of glove box i have the numbers for the 2 of them but need the numbers for the one next to the mode door actuator that should be replaced while i'm in there thanks Again
there are actually 4 -
LEFT/MAIN - ACDELCO 15-72974
RIGHT/REAR - ACDELCO 15-73428
MODE - ACDELCO 15-72654
RECIRCULATE - ACDELCO 15-72974 - yup - same actuator as the LEFT/MAIN -
that would be the LEFT/MAIN - ACDELCO 15-72974 - $59 - with free shipping -
Discussion Starter #12
Today I install Temp Actuator ACDELCO 15-73428 Easy Peezy. Tomorrow new Blower mine has been loud for a while left everything out to have nice access should be also Easy thanks Again : )
Discussion Starter #13
Hey Bass, All Done with the Blower Nice and Quite and strong. I wish I knew they screw into plastic didn't realize it but caught on after the first one thank God. Also I Am not hearing the uptick when I press the recirculator like before could i have somehow disconnected it when installing the blower let me know Thanks.
sure - anything is possible -
check for codes -
if it got unplugged - there should be a code
Discussion Starter #15
check for codes -
Ok Will Do, is the connector for the recirc Actuator in that area Thanks
1 - 15 of 15 Posts
