Greetings,
Just got my 04 CTS-V a few months ago ... love it! Unfortunately right now it has an issue ruining the fun lol
I had the not uncommon "check charging system" while and the car died while driving. Did the basic tests ... battery checks out good. Battery reads battery voltage with the car turned off or running ... sounds like the alternator isn't doing anything. Belt looks fine. Resistance between the alternator body and battery ground is .2 ohms ... seems ok.
That was enough for me, so I went ahead and replaced the alternator ... WRONG ... same symptoms. After reading many threads, I thought for sure it was the alternator connector orange wire ... the PO had replaced broken engine mounts, so it seems to fit the profile. No luck ... the orange wire is reading battery voltage which seems ok. The problem doesn't fit the profile of the grey wire being the issue.
I know I have general grounding issues (don't we all haha). I've had the oil temp sensor problem like so many others. Cleaning up the ground under the hood strut seems to help that. I do still get lots of static on the radio sometimes, and oil temp sensor will still occasionally jump around.
I'm going to try and test the alternator power wire today ... that one's a little harder to get to ... wish I'd checked it when I replaced the alternator haha. Does the 04 V have a fusible link or an alternator fuse? I have a service manual but it is really vague on this point compared to other CTS models.
Any help from the experts here would be so much appreciated!
Cheers,
PRSplayer
Cheers,
PRSplayer
