Upgraded my speakers. Want to keep using stock head unit as well as amps. The system comes as follows (Non-Bose) 4 ohm tweeters, 2 ohm 5.25 front door speakers, 4 ohm rear door speakers, and the sub is a 2 ohm/2 voice coil 10 inch unit.
I have upgraded (plug and play) Infinity Component Reference speakers (both are 4 ohm).The rear doors are a pair of 5.25 Pioneer Premier Mids (4 ohm).I tell'ya the tweeters are a pain to pull out of their posts and because of the design putting in new ones is a crappy electrical tape job to fit in those existing holders. I liked the sound for about a day when I relized the stock sub's gotta go.
Now to my question. I would like to plug and play the sub as well. The system has sufficient power for my taste. I'm looking for a tight sounding sub, same 10 inch size (I need the trunk space). Will a 4 ohm dual voice coil lower powered sub work, I also found an Alpine Type S, Kicker Comp VR that are both 2 ohm - dual voice coil subs. MB Quart also does one. Will any of this work? Suggestions? I posted some pics of the old speakers for a lok at the stock units. Any help from you Pro's would be appreciated!!
