Started the car in the morning as usual to warm up. Came back 5 or so minutes later and saw my check engine light was on, service engine soon on DIC. Drive about two miles, got on the main road to about 25mph and then no Acceleration And RPMs wouldn’t go over 3k. Turned around and drove home. When I put the car in park, the RPMs went wild from its normal idle to 1200 jumping up to 2000 and back down. It did this several times so shut the engine off. I feel like I’ve thoroughly combed through the P 2176 code posts. Throttle body position relearn not done. I did the throttlebody relearn Procedure.
*️⃣ Turn the ignition to the on position for three minutes, turned it off, started the car for 30 seconds, shut the car off, then started it and let it run for about five minutes.
(Is this the proper procedure?)
Seemed a little rough in the beginning but leveled itself out. Drove for five minutes and went right back to square one. I found two vacuum leaks, possibly played a role in the rough idle? I’m going to check the accelerator ignition pedal sensor for voltage next and trace it to the ECM. Is there anything I’m missing or overlooked?
