1 - 2 of 2 Posts
2003 Cadillac Seville STS
Changed the rotors and pads on my 03 STS last weekend. The job was very easy (3 bolts not counting the wheel) and my $12 PEP Boys tool worked well for turning in the pistons. The rotors went from good in April to horrible in May. The right rear was so bad there was a section of the rotor about 4 inches long on the one side the pad was not touching. Shook the car very badly when applied. The original brake pads looked like new with 31K miles. Installed EBC drilled and slotted rotors with Raybestos ceramic pads. So far very smooth braking and no noise.
Good to hear, if you only did the rear brakes I've found bedding them in is unnecessary and more importantly dangerous because it can damage your front rotors that are already bedded. I know because I replaced my rears, bedded them, overheated my fronts and ended up loosing a chunk of rotor in the process, ended up replacing the fronts too...
1 - 2 of 2 Posts
