1 - 1 of 1 Posts
03 Escalade rt turn signals glow solid when brakes applied, when signal on it blinks until brakes are applied, replaced bulbs, cleaned corrosion, no change. Also cruise control works until you signal rt then it disengages. Prior to this the traction control ABS would occasionally come on during take off, mechanic said possibly brake pedal issue but haven’t taken back for the fix. That issue is less rare if don’t romp the gas at take off. The turn signal thing is a real issue, left side is fine.
1 - 1 of 1 Posts
