2003 CTS Luxury/Sport package
Anytime i go through the car wash ill have water leak in when reaching the dryers that only comes in from the rear passenger side air bag indicator badge. Now my question is if this is indeed a clogged sunroof drain or something else? Ive only seen others with water leaking in have it come in from different locations.
2003 CTS
the drains are either clogged or the tubing has come loose. mine were left loose when I had some hail damage repaired a few years ago.
Thanks for your responses, I'm going to try and blow out the drain today and if that doesn't correct the problem i'll pull down the headliner to see whats really going on. Would a snake fit in the drains to help with a clog that may be too stubborn for just air?
Drain was clogged enough to not allow proper flow but didn't restrict completely. Cleared them all out today and went through a local Mikes and no leaking inside.
