03 CTS
I have a P0128 code that came up 2 weeks after my warranty ran out. I understand I need a new thermostat. I cant afford to have a professional do it and was hoping that someone could give me instructions and diagrams on how to repair. Im very far from being knowlegable in automotive repair and was hoping this is something I can do on my own. Any help would be greatly appreciated.
Thanks!!
Brandon
2003 CTS "Ebony Maria" 2005 Cadillac STS "Grace"
try and contact forum member SammyZ...he is a very knowledgeable person on this and could probably help you out a lot
CTS 03
It's a lot of work but not difficult. The intake manifold has to come off then you can remove the bolts that hold it in. It seems Cadillac put the t-stat in the center of the engine. I purchased a new t-stat, with the housing because someone told me that sometimes the housing cracks. Also purchase the two O ringing that hold the side fill tube in. The parts cost about $60. Get a gal of the GM antifreeze as well because you will loose some. The project took me 8 or 9 hours but I'm not an expert, i have average DIY skills.
Cadillac Cts
Thermostat Replacement LA3, LY9
Removal Procedure
Remove the thermostat housing. Refer to Thermostat Housing Replacement .
Thermostat Housing Replacement LA3, LY9
Removal Procedure
Remove the coolant outlet pipe. Refer to Coolant Pipe Replacement - Outlet .
Tools Required
J 38185 Hose Clamp Pliers
Removal Procedure
Drain the cooling system. Refer to Draining and Filling Cooling System .
Position the J 38185 to the clamp in order to remove the radiator inlet hose (1) from the coolant outlet pipe.
Remove the bolt (2) securing the following to the cylinder head:
The oil level indicator tube (4)
The coolant outlet pipe (3)
The engine front lift bracket (1)
Remove the coolant outlet pipe (3) from the thermostat housing.
Remove the O-ring seals from the coolant outlet pipe. Discard the O-rings.
Remove the intake manifold. Refer to Intake Manifold Replacement in Engine Mechanical-2.6L and 3.2L.
Remove the intake plenum. Refer to Intake Plenum Replacement .
Relieve the fuel system pressure. Refer to Fuel Pressure Relief Procedure in Engine Controls-2.6L and 3.2L.
Refer to Quick Connect Fitting(s) Service (Metal Collar) in order to disconnect the following quick connect fittings from the fuel rail:
The return hose/pipe (1)
The feed hose/pipe (2) Plug the open outlet ports to prevent fuel loss and contamination.
Disconnect the fuel injector electrical harness connector (2) from the engine wiring harness connector (3).
Disconnect the fuel pressure regulator vent tube from the fuel pressure regulator.
Remove the fuel rail if intake manifold replacement is necessary. Refer to Fuel Injectors and Fuel Rail Replacement in Engine Controls-2.6L and 3.2L.
Remove the intake manifold bolts (1).
Remove the intake manifold (2) from the intake manifold flange.
Remove the seals (3).
Mask off the open ports to the intake manifold flange, in order to prevent foreign objects from entering the engine.
If necessary, disassemble the intake manifold. Refer to Intake Manifold Disassemble .
Clean and inspect the intake manifold. Refer to Intake Manifold Cleaning and Inspection
Remove the thermostat housing bolts (1).
Remove the thermostat housing (2) with thermostat, from the engine.
Remove and discard the seal ring.
Remove the thermostat from the thermostat housing. Refer to Thermostat Replacement
Complete the following in order to remove the thermostat from the thermostat housing:
Depress the ears on both sides of the thermostat.
Rotate the thermostat until it clears the retaining feature of the housing.
Release the pressure from the thermostat.
Pull the thermostat from the thermostat housing.
2003 Cadillac CTS
Tools Required:
-J 38185 Hose Clamp Pliers-is this the only specialty tool I am going to require?
BMoe
