Ok i need help....what could be the problem here!?
Car won'won't start via the ignition switch. If I pull the starter relay and jump it with a wire, the engine will turn over. I just installed a brand new starter & solenoid and brand new battery. I have all power inside the car with key on. When I turn key to start, I get a loud slow consistent banging noise which sounds like it's coming from passenger side and I can feel it in the driver seat. So something is responding to the key being turned to start, but the starter is not.
I have read it could be ECM but I want to rule out everything else. Not sure where to go from here, ease help. I also see alot I'd threads about starter problems but none of them have a definitive answer to the problem. Most cases are intermittent so people seem to just deal with it. My problem however is persistent and just won't start via key in ignition.
Any help and guidance would be appreciated!
