I currently have 3 seperate switch light issues. The volume/mute button are no longer illumiated. I did a search and found the write up for replacing those.
My second issue is the window control on the driver side. The driver/passenger window switch, mirror adjustment pad and selector are not lighting up now. The rear window control on the driver side are good. So pretty much just 1/2 of the driver control area has no light. Ideas? I have not taken it out yet, are they seperate units or combo?
I also noticed that the cup holder and ashtray lights are out too. :rant2:
I'll recheck the fuses again, but they all checked out last time I put a test light on them. Small issues....but you know how that goes.
BTW- Just replaced the water pump a few weeks ago, it had been leaking coolant over time so I bit the bullet and changed it out. The dealer wanted almost $300 for it!! Went to Autozone and picked one up for $130 out the door. There is no core charge due to the impeller assembly being a pressed unit. Really can't complain, the stock unit lasted 120K.
TIA
Walter
