02 Seville, 04 SRX
Ever since I broke clips off the door panels in my Eldorado, I am reluctant to remove another one without consulting the forums. I need to replace the driver's side mirror on my Seville. I will definitely need to remove the top portion of the window trim, maybe the entire panel. Can someone give me a quick replay to tell me how to remove what I need so that I don't break any plastic clips? Thanks
'98 STS (RIP @ 206,xxx miles)
If you are talking about replacing the mirror glass, it is not necessary to remove the door panel.
To R&R the entire mirror, the panel has to come off. There are four screws; one at the bottom rear corner, one behind the plastic panel behind the door-open handle, and two behind the leather flap (held in place be Velcro) behind the door-close pull.
Lift straight up far enough to remove one electrical connector and the link rod to the manual door lock.
The internal panel fasteners are the push-in-the-center to release type.
02 Seville, 04 SRX
I have the whole assembly with the motor in it. There are 3 bolts tha twill hold it on that connect behind the tweeter.
99 Cadillac STS
If anyone could scan the manual page and upload it, I sure would appreciate it.
Thanks,
Rob
