02 ESCALADE EXT 140K DTC p0200 & p0307 questions
4K views 1 reply 2 participants last post by  BMWUTAH
I am getting codes p0307 and p0200. I know normally you would start with the highest dtc first P0307 would be cylinder misfire on cylinder #7 I dont visually see a broken plug wire or that it rubbed on anything. I will try wetting the wires and look for arcing and pull the plug. I am curious though as the P0200 I am thinking is more injector related which if it was dirty or shorted would throw the 200 and then also the p0307. I will try to ohm the injector and check with a noid light for pulses in the morning. It does have a stumble from idle when accelerating at idle feels like it may stall but hasnt yet. I will probably end up doing a full tuneup. Plugs wires fuel and air filters. I am thinking it may not be a bad idea to pull the injectors and have them sonic cleaned and flow tested. If anyone has any other suggestions please let me know.
Chris
