I thought ok the cleaning may have messed up the thermostat,
so I put a new one in
I hope you used either an ACDelco or STANT brand T-stat -
and not some el-cheapo house-brand unit -
How to do I get all the air out of the system?
the system is SUPPOSED to be self-purging -
through the PURGE LINE -
the PURGE LINE is the only way of expelling air from the Northstar cooling system -
it is a 3/8 diameter hose that goes from a hollow bolt in the thermostat/waterpump housing area of the engine - and plugs onto a nipple on the side of the SERGE TANK -
with the engine running - there should be a gentle - constant flow of coolant - from the engine - to the serge tank -
if there is no flow - the most likely cause is a blockage in the hollow bolt -
follow the hose towards the engine - with the engine OFF - remove the hose - use a straightened metal coat hanger - or something similar - and poke it into the hollow bolt -
the coat hanger should go in about 2 1/2 inches -
once the hollow bolt is cleared - you can briefly start the engine to verify coolant flow - be sure to use some sort of container to catch the coolant so you don't make a mess -
check the hose and serge tank for blockage -
