02 Cadillac Deville
I have an 02 Cadillac Deville recently i had some codes pop up (See Below)
P0101 Mass air flow
P0121 Throttle Pedal Position Sensor
PO0171 Bank 1 System to lean
PO0174 Bank 2 System to lean
P1416 No DTC Definition found see service manual
I have replaced the the idel control sensor, Secondary air injection and Mass air flow sensor also the plenum duct
I am lost with this car when i replace the plenum duct the service engine light had cut off and about a hundred miles later it cut on with the above codes.
Please help with any suggestions thanks
98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
Re: 02 Cadi deville (Help Please)
Do you have the MAP sensor seated and plugged in? The mass air flow sensor on this vehicle should be between the air cleaner housing and the throttle body. Why was that replaced? When you replaced those items, did you clear the codes to see if they would reappear again?
What was the car ORIGINALLY doing before you decided to replace those parts?
These cars tell on themselves when sick. ALWAYS PULL/GET THE CODES.
P0171 and P0174 indicate a big vacuum leak - recheck all your connections -
something is loose or fell off -
P1416 - Secondary Air Injection (AIR) System Bank 2
here is an excellent source for code definitions -
http://myweb.accessus.net/~090/dtcobd2p.html#pow
Hmmm............. Define your "plenum duct".
........... and if you did, in fact, replace the rubber/steel coupler between the throttlebody and intake manifold, are the band clamps and MAF clamps on the intake ducting tight ? ANY loose/cracked intake ducting at or after the divorced MAF will set codes.
Are the codes Current or History ??? It makes a big difference.
02 Cadillac Deville
Ive checked the mass air flow I change it before because of the code that pooped up ive changed all these parts from cheapest to highest hopeing that it would solve the problems that I was having I just ran to the store a few minutes ago and the SES light has cut off and fills ok I swear this car has a mind of its own but at times it will idle a little rough
The EXACT definition of throwing parts at a problem, and GAURANTEED the BEST way to waste large amounts of money, quickly.
You need to diagnose and understand the problem, before repairing/replacing anything.
As sub asked, which of these codes are current, and which are history?
