91 Seville / 92 Sedan Deville / 02 Deville / 08 DTS <--Current
Hey guys hope you can help me with this one? My car stalled the past couple time I drove it. It starts right back up but today merging on the parkway I gave her gas and it sounded like the engine was gona quit but it half stalled/sputtered lost all power then it came back and was running fine? Check engine light came on and I pulled the code it's PCM P0385. I read something on here that suggests the CKP sensors may need replaced? Is this correct and what's involved labor/money wise. Thanks, Sam
Re: 02 deville PCM P0385 and engine stall
the original CKP - crankshaft position sensors - were KNOWN to fail -
not a question IF they would fail -
but WHEN they will fail -
the replacement parts are:
ACDelco 213-1578 - $34.44 - with free shipping -
http://www.amazon.com/ACDelco-213-1578-Original-Equipment-Crankshaft/dp/B000C9JORO/ref=lh_ni_t?ie=UTF8&psc=1&smid=A30UAHS71NDWIQ -
and -
ACDelco 213-1579 - $40.00 - with free shipping -
http://www.amazon.com/ACDelco-213-1579-Original-Equipment-Crankshaft/dp/B000C9HW00/ref=lh_ni_t?ie=UTF8&psc=1&smid=A11LEJUKDF2NKE
as far as labor goes -
it is not an impossible DIY project -
an independent shop might charge 1 1/2 hours labor -
the dealer would charge a left arm - or your first born -
Thanks Basscatt!!
Here you go - drop the lower air deflector, remove the oil filter adapter. Tight work with a 10mm wobble socket - double-locked electrical connectors. Get the CKPs made in Japan by DENSO - the old, rotten ones were made in Mexico by Siemens.
More info in Tech Tips or Google "cadillac forums northstar engine ckp replacement"
Newer models - your 2002 - use 2 different CKPs that will fit only one hole one way.
Click a thumbnail to enlarge, use your browser <-- to back out ..........
