1 - 15 of 15 Posts
I recently purchased an 01 Deville, a few days of driving and the check engine light started flashing on and off. the onstar diagnostics said it was possiable misfire..any suggestions . is this a problem i can fix on my own . if so what are the steps..Thanks
The Northstar Tuner
Do you know what cylinder is misfiring?
no, i cant really hear a misfire when i accelerate so im assuming it is only one cylinder. havn't gotten formal diagnostic ran yet.
The Northstar Tuner
how many miles on the car?
The Northstar Tuner
When did this occure?
The Northstar Tuner
the day after i bought it and drove it home. im thinking it could be the engine cleaning they did. the engine compartment was pristine. so im almosty positive they cleaned it. you thinkn that could be a possability, just plug boot ?
The Northstar Tuner
I have the engine out of an 00 Deville. It was wrecked bad at one time. The hood must have been off the car for some time. I pulled the coil cassettes off and the electrode had rust on all of them. I know the owners of the car for the last 3 years. It has not had a misfire condition, but The coils are bad.
Water can get down into the boots.
Discussion Starter · #14 ·
no, all ive done at this point is run diagnostics. when i change plugs, does it have to be reset in order for the engine light to go off or does it do it automatically once the problem has been fixed
2010 DTS
The light will go off after 3 ignition cycles with no fault detected, but you can clear it through the DIC after you pull the codes.
1 - 15 of 15 Posts
