My cooling fans are intermittently kicking on and my A/C is not working at idle because of it. I pulled the relays and jumpered cooling 1 relay and the left fan kicked on at high speed. Then I jumped cooling 2 relay and both fans kicked on at low speed. I took a mutimeter and measured from ground to the coil pin of the relay and got 13v. I tried switching relays and bending the pins a little incase the socket wasn’t making a connection but it still didn’t work. I checked the main ground right under the accumulator and it was fine. Is there another ground for the relays? Or is it not working because the high speed is burned out of the right fan?
