1 - 20 of 23 Posts
2000 Deville
Just started out of nowhere last week. Car has been perfect, but looked out in the street and the back end is jacked way up. Air shocks are fully inflated. The car looks ridiculous.
I pulled codes, and only the following two were set:
IRC U1016 Invalid or missing data for primary ID
RCC U1000 Invalid or missing data for primary ID
When I turn the ignition on, the compressor starts about 5 seconds later and runs for 60 seconds... Even though the shocks are fully inflated.
I popped the arm off the control arm on the left side and moved it all the way up and all the way down with the ignition on and nothing happened. No air venting and no compressor starting.
I think the problem is either the ride height sensor or the exhaust valve on the compressor. My question is: How do I test each component so I know what is malfunctioning?
2010 DTS
That's a normal start up test run.
Exhaust valve (or solenoid) would be my guess.
Running for 60 seconds is not normal. After startup, it should only run for 5 seconds or so, then adjust further if necessary.
2000 Deville
Discussion Starter · #4 ·
I would have thought ride level sensor because no matter which direction I moved the arm, nothing happened. Wouldn't the compressor come on at one extreme and exhaust valve open at the other? By moving the arm, I couldn't make either action happen.
yes -
pushing the rod UP simulates a low rear end -
and should fire up the compressor -
pulling the rod DOWN simulates a high rear end -
and should activate the exhaust solenoid -
check the ELC fuse and relay under the back seat -
the ride height sensor is completely sealed in epoxy -
I have never heard of a faulty sensor -
it is not uncommon for the exhaust solenoid to fail -
but - a fault code is usually set -
2010 DTS
:hide: Oops, I missed that. Yeah 60 seconds is waaay too long.
If the sensor/switch is at full extension, I suspect it would not activate the compressor. At least that would be my guess.
If you allow the sensor arm to swing all the way up (it is spring loaded), it will set a code for a faulty sensor and the compressor won't turn on. Anywhere before all the way up should trigger the compressor.
no springs in the sensor -
I took one apart -
there is an inferred photo cell inside the box -
the lever is attached to a wheel - with a slot in it -
the slot allows or blocks the light -
Must be an F45 thing then. All my sensors spring up when the pushrod is disconnected, and trigger a code and SERVICE SUSPENSION SYS message.
that's possible
2000 Deville
Discussion Starter · #11 ·
Land vehicle Vehicle Car Luxury vehicle Sedan
This is how ridiculous my car looks.
I've checked the relay and fuse and both are OK. Does anyone have a procedure for testing the exhaust valve and load sensor? I really hate to just start changing parts.
I would simply remove the air line from one of the shocks -
let all the air out -
reattach the air line -
start the engine -
see what happens -
2010 DTS
We know the compressor works, so this sounds like a bad sensor/switch.
EDIT: All been covered in previous posts.
2000 Deville
Discussion Starter · #16 ·
Submariner409. I've searched and can't find the posts. Maybe you could point me in the right direction with a link?
did you try removing one of the airlines
to deflate the shocks like I suggested?
This thread
had 15 posts prior to this one - suggestions range from solenoid control head to compressor to height sensors to air lines.
Which model Deville - base, Concours (? in 2001 ?), DHS, DTS ? It can make a difference in the level control configuration.
You could also surf through Tech Tips and Suspension. (Not trying to be difficult, but it's all in here somewhere.)
2000 Deville
Discussion Starter · #19 ·
Sorry... I've seen all the "could be's", "might be", "try this", and "try that" posts...
My question is very specific and I can't find a thread on it...
Does anyone have a procedure to test the load level sensor and the exhaust valve?
And, yes, I let the air out of the system be removing a line. It just pumped up to max again
YES - but it requires the TECH2 tool -
1 - 20 of 23 Posts
