1 - 14 of 14 Posts
2005 Deville
2012 CTS AWD, 2005 DeVille
I tried to search the forum and find a solution, but couldn't find any info. I have a 01 DeVille with a 4.6L that has a real intermittent problem. On occasion, the car will stall when starting and I have to keep my foot on the gas to keep the RPMs up enough to get it running. Other times, the acceleration will stick like the cruse control is on. I was going 45 mph yesterday without my foot on the pedal. This happened a few months ago and I cleaned the MAF. It did not happen again until yesterday. Stall on start, acceleration sticking. Today, I pulled into work and the RPM's were at 1800. Hit the pedal and it went to 3500 and took a minute to drop back to 1800. Turned the car off and restarted and normal 750 RPM's only seconds later. Do I need to clean the MAF again? There are no on-board codes and it is such an intermittent problem that it is hard to diagnose. Any suggestions?
How was it cleaned? Both sides and perimeter of the throttle plate, as well as the bore?
2005 Deville
Took the MAF off and cleaned the throttle body better. That seemed to do the trick! Time will tell. Thanks!
did you check for codes?
1991 Deville
Had a similar issue with a other sucking air from tb base gasket till warmed up. ecm tried to compensate
2005 Deville
Discussion Starter #10
Cleaned the hell out of the throttle body. Today RpMs ran high again, but it didn't stall yet.
Continue your cleaning spree to the IAC and its bore.
2002 STS, 2005 CTS 3.6
Take out the IAC, clean it and screw in the plunger at the end as they usually come loose over time and then seize up with gunk.
2005 Deville
Discussion Starter #14
Had a friend that had an extra IAC, so we put it in. I think that solved the problem!
1 - 14 of 14 Posts
